Home > General > 40 mph + whine ... gearbox/difff or bearing
PC76
ok, well the longer it goes on the more i am confused. i have a whine when travelling above approx 40mph. when it first appeared i would swear it was a rear bearing. i checked for play when i replaced the rear breaks + shoes but i didn't find any play.
when i am driving now i'm not so sure it could be coming from the centre of the car or even the front...
my milage is 113k so i am wondering if it could be either the transfercase / diffs or indeed a wheel bearing..... (i doubt gearbox due to it being speed related and not revs related)
can anyone point me in the right direction, i have tried you tube and haven't found a similar example. i will try and record it and post tonight / tomorrow but not sure my phone will pic the noise up.....
FYI - I have a 2010 facelift 3.0 TDV6
Post #575955 Tue Feb 26 2019 6:32pm
swatkins
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
I have exactly the same problem started two weeks ago mines going to independent tomorrow will let you know what they say.
Best
Stewart
Post #575976 Tue Feb 26 2019 7:38pm
swatkins
Its a new front differential on mine!!!
Post #576017 Wed Feb 27 2019 1:16pm
PC76
Gulp...
How did they prove it?
Post #576023 Wed Feb 27 2019 3:17pm
swatkins
Experience??? I dont know I do IT. Cost with transmission oil and filter change and engine oil and filter change and MOT £1600 Including VAT, if that helps. Start saving, Rear one will probably need doing soon.
Best
Stewart
Post #576024 Wed Feb 27 2019 3:26pm
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
In my old TDV6, I remember having a whining noise from the front end if memory serves and it ending up being a knackered alternator... pain the proverbial, but not as horrific as a drive shaft! 2008 RRS HSE Stornoway Grey
Post #576094 Fri Mar 01 2019 7:53am
PC76
Thanks Richy.
I have discounted anything engine related as it only happens at speed no matter what revs.
Stewart,
have you got it back fixed yet?
Post #576105 Fri Mar 01 2019 10:10am
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
i had similar on older RRS.
it was in the end the left rear wheel bearing.
it was not so clear from trying to check for play in it.
but i knew it had to be because the the noise was speed dependent.
one thing you could do it check on an open road by driving and swerving left and right.
this is how i knew it had to be left side.... you could notice a change in sound when serving right.
anyway... just 2p from my last whine in the back Laughing
but your seems to be already diagnosed as more serious Shocked 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #576116 Fri Mar 01 2019 1:19pm
PC76
Not diagnosed yet MGO...
I don't take anything on face value...
I will be spending a couple of hours over the weekend crawling underneath it to try and confirm with at least 99% certainty Laughing
Post #576126 Fri Mar 01 2019 3:47pm
swatkins
PC76 wrote:
Thanks Richy.
Stewart,
Goes in Wednesday but mine makes more noise when turning right do you reckon they are having me on?
Post #576151 Fri Mar 01 2019 10:30pm
PC76
Stewart,
I would start a separate tread and search the forum for other diff faults to confirm the symptoms. I'm not familiar with diff faults so can't comment sorry.
Post #576256 Sun Mar 03 2019 10:32am
PC76
Can some one recommend a brand of bearings?
I have seen the following brands at various prices...
Myle
NTN
Brit Part
First Line
Borg & Beck
Post #576257 Sun Mar 03 2019 10:41am
swatkins
PC76 wrote:
Thanks Richy.
Stewart,
Got car back today diff is fine! it was two front wheel bearings in the end. Had the diff and transmission oils done as well.
best
Stewart
Post #576672 Thu Mar 07 2019 10:43pm
