![]() | Home > General > 40 mph + whine ... gearbox/difff or bearing |
swatkins Member Since: 01 Apr 2017 Location: Essex Posts: 57 ![]() ![]() ![]() |
I have exactly the same problem started two weeks ago mines going to independent tomorrow will let you know what they say.
Its a new front differential on mine!!! |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Gulp...
Experience??? I dont know I do IT. Cost with transmission oil and filter change and engine oil and filter change and MOT £1600 Including VAT, if that helps. Start saving, Rear one will probably need doing soon.
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 ![]() ![]() ![]() |
In my old TDV6, I remember having a whining noise from the front end if memory serves and it ending up being a knackered alternator... pain the proverbial, but not as horrific as a drive shaft! 2008 RRS HSE Stornoway Grey |
Thanks Richy.
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
i had similar on older RRS.
Not diagnosed yet MGO...
Goes in Wednesday but mine makes more noise when turning right do you reckon they are having me on? |
Stewart,
Can some one recommend a brand of bearings?
Got car back today diff is fine! it was two front wheel bearings in the end. Had the diff and transmission oils done as well. best Stewart |
