![]() | Home > Technical > RRS 2011 SC alarms at night |
freddi Member Since: 24 Jun 2006 Location: SYDNEY Posts: 21 ![]() ![]() ![]() |
Hi there, my RRS 2011 SC alarms at night and the neigbours love me. I have reomoved the horn fuse but this is not a fix. Help |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9022 ![]() ![]() ![]() |
I'd start with the bonnet catch. My previous RRS did this - alarm would go off randomly, changed the catch and no more false alarms. You could pull the catch sensor wire and, I think, short it to see if false alarms stop. A new catch is easy to fit or you could just run with the sensor disabled. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
Thought I read somewhere people bridge the switch wiring plug out with paper clip to disable it temporarily, might have that wrong though.
Thank you. I heading out into the dark. See how i go. Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant! |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Mine was the bonnet catch. Easy fix |
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 ![]() ![]() ![]() |
Bonnet catch - pull connector insert tin foil, replace, done |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Same issue on my L494, bonnet switch replaced under warranty.
It was the left rear passenger door actuator ! Who would have guessed ? My mechanich fault found it ! Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant! |
