Home > Technical > RRS 2011 SC alarms at night
freddi
Australia 2011 Range Rover Sport Supercharged Fuji White
Hi there, my RRS 2011 SC alarms at night and the neigbours love me. I have reomoved the horn fuse but this is not a fix. Help Bow down Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant!
Post #575927 Tue Feb 26 2019 8:52am
Brit Plumber
I’ve read that the bonnet switch can cause issues. Have you searched the forum? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575929 Tue Feb 26 2019 9:12am
I'd start with the bonnet catch. My previous RRS did this - alarm would go off randomly, changed the catch and no more false alarms. You could pull the catch sensor wire and, I think, short it to see if false alarms stop. A new catch is easy to fit or you could just run with the sensor disabled. 2012 SDV6 - it's missing a couple of cylinders
Post #575931 Tue Feb 26 2019 9:18am
Thought I read somewhere people bridge the switch wiring plug out with paper clip to disable it temporarily, might have that wrong though.
Post #575932 Tue Feb 26 2019 9:21am
freddi
Thank you. I heading out into the dark. See how i go. Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant!
Post #575935 Tue Feb 26 2019 10:01am
Cymruambyth
Wales
Mine was the bonnet catch. Easy fix Thumbs Up Steve.
Post #575937 Tue Feb 26 2019 10:21am
Hamtheman
South Africa 2011 Range Rover Sport Supercharged Alaska White
Bonnet catch - pull connector insert tin foil, replace, done
Post #575942 Tue Feb 26 2019 11:33am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Same issue on my L494, bonnet switch replaced under warranty.
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #575974 Tue Feb 26 2019 7:25pm
freddi
It was the left rear passenger door actuator ! Who would have guessed ? My mechanich fault found it ! Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant!
Post #622274 Sun Feb 27 2022 8:35am
