Home > Technical > Zf8hp transmission
Chas9
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Zf8hp transmission
Morning guys looking for some info on oil spec for zf8hp transmission . I drive a rrs diesel v6 face lift version and was hoping some one could advice me on which brand and grade of oil to use to top up my transmission. Cheers chas
Post #575356 Sat Feb 16 2019 10:58am
this
https://www.ebay.co.uk/itm/ZF-Lifeguard-8-...SwtfhYtGJg
Post #575357 Sat Feb 16 2019 11:07am
Chas9
Magic . Oooft not a cheap one ae. Thanks again Confused
Post #575359 Sat Feb 16 2019 11:17am
how do you know it needs topping up ? and how will you do it ?
Post #575362 Sat Feb 16 2019 11:43am
Chas9
Just checking as a precaution mate apparently there's a level plug on side of transmission. Looking at doing oil and sump pan assy change during summer. So having a look will give me a heads up to access available.
Post #575363 Sat Feb 16 2019 12:19pm
so you will need a lot of oil then, rather than top up.
Your better off getting it flushed at that age or draining via the sump plug.
Removing the sump is a pain, and can be difficult to reseal
Post #575367 Sat Feb 16 2019 2:33pm
Chas9
Ye may think about flush altho only 36k on vehicle.
Post #575369 Sat Feb 16 2019 3:30pm
Disco_Mikey
A flush is alway more beneficial than a sunp/refill
It's not a dirty filter that causes gearbox issues and wear, it's dirty oil. A flush removes over 98% of the old oil, as opposed to 40% by draining the sump Thumbs Up
Post #575370 Sat Feb 16 2019 4:06pm
Chas9
Cool Mikey would you happen to know anyone in Scotland I could contact about flush.cheers
Post #575371 Sat Feb 16 2019 4:13pm
Disco_Mikey
I have the equipment for 8 speed flushing Thumbs Up
Post #575379 Sat Feb 16 2019 5:38pm
Chas9
Disco_Mike....
Could you explain flushing process. Does it filter and recondition oil or just filter any sludge and contaminates.cheers
Post #575384 Sat Feb 16 2019 7:08pm
Old oil comes out and disposed off
New oil goes in.
Post #575385 Sat Feb 16 2019 7:14pm
Chas9
Cool sounds good. So clutch packs control block torque converter and charge pump would be flushed.
Do you happen to carry this procedure out for others.cheers
Post #575390 Sat Feb 16 2019 7:23pm
A number of places do this.
Just make sure they use oil suitable for the 8 speed.
And not oil that is red as that should ring alarm bells.
Mike is in Scotland.
Goto YouTube and search gearbox flush to give you an idea
Post #575393 Sat Feb 16 2019 7:36pm
Chas9
Cheers Andy thanks for your help
Post #575394 Sat Feb 16 2019 7:37pm
