![]() | Home > Technical > Heating help Please |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
It is normal, on auto the fans will not kick in fully untill the engine has warmed. Enables the engine to warm quicker, rather than blasting cold air into the cabin. Once the engine/matrix can provide heat, the fans speed up to circulate warm air. MY12 RRS HSE
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
Ok will try if when the engine is up to temperature, thanks 2010 3.0 TDV6 RRS Overfinch GTS
