Home > In Car Electronics > Surround Camera Retro fit. |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Project so far.
Mon Feb 04 2019 10:38pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5018 |
Will be very interested how that all works out, when I changed my mirrors I ended up fitting a couple of the rear view cameras in the mirrors as already had surround system and couldn't find leads of any sort to connect the RRS2 6pin into the RRS1 4pin system, also as the original cameras had the puddle light integral in camera have two permanent camera faults listed which I put down to the puddle lights although everything works fine. Would like to see if I could get rid of the faults.
Mon Feb 04 2019 11:10pm |
I’ll let you know how it goes Col.
Sat Feb 09 2019 10:19am |
I get this sort of thing Chris if that is what you mean, don't know if same as RRS2 though, changes colour the nearer you get to things, yellow, orange then red I think along with the sensor beep increasing, also get the "bendy" yellow lines with the steering wheel movement.
Sat Feb 09 2019 10:46am |
Thanks Col, I couldn’t get mine to work at first so wondered if the L320 never had it. But after seeing yours I cleared the DTCs and now it works a treat! 2019 5.0 SC SVA (Current)
Mon Feb 11 2019 9:02am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
I'm also keen to see how this turns out and what parts & coding are needed etc. Assume you wont get the surround camera icon on the main display without a new head unit?
Thu Feb 14 2019 9:09am |
You shouldn’t need a new head unit, it just needs the CCF updating to effectively turn the option on and then the icon will appear.
Thu Feb 14 2019 11:10am |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 |
retro fitted all round cameras to L494 I wonder?
Sat Feb 01 2020 10:33am |
It’s not difficult as a DIY job but the most expensive part of it will be buying the mirrors (salvage is better as you only need the bottom trim) and the IID tool. The special cables aren’t cheap either but you may be able to obtain those through salvage also. 2019 5.0 SC SVA (Current)
Sat Feb 01 2020 11:22am |
Rs4-cab Member Since: 01 May 2021 Location: Northampton Posts: 4 |
Hi
Sat May 01 2021 8:55pm |
