![]() | Home > In Car Electronics > Surround Camera Retro fit. |
Project so far.
Will be very interested how that all works out, when I changed my mirrors I ended up fitting a couple of the rear view cameras in the mirrors as already had surround system and couldn't find leads of any sort to connect the RRS2 6pin into the RRS1 4pin system, also as the original cameras had the puddle light integral in camera have two permanent camera faults listed which I put down to the puddle lights although everything works fine. Would like to see if I could get rid of the faults.
I’ll let you know how it goes Col.
I get this sort of thing Chris if that is what you mean, don't know if same as RRS2 though, changes colour the nearer you get to things, yellow, orange then red I think along with the sensor beep increasing, also get the "bendy" yellow lines with the steering wheel movement.
Thanks Col, I couldn’t get mine to work at first so wondered if the L320 never had it. But after seeing yours I cleared the DTCs and now it works a treat! 2019 5.0 SC SVA (Current)
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
I'm also keen to see how this turns out and what parts & coding are needed etc. Assume you wont get the surround camera icon on the main display without a new head unit?
You shouldn’t need a new head unit, it just needs the CCF updating to effectively turn the option on and then the icon will appear.
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
retro fitted all round cameras to L494 I wonder?
It’s not difficult as a DIY job but the most expensive part of it will be buying the mirrors (salvage is better as you only need the bottom trim) and the IID tool. The special cables aren’t cheap either but you may be able to obtain those through salvage also. 2019 5.0 SC SVA (Current)
Rs4-cab Member Since: 01 May 2021 Location: Northampton Posts: 4 ![]() ![]() ![]() |
Hi
