Home > General > 2.7tdv6 funny loud tapping noise
HEFF
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
i was driving normally. then my rrs started to make a very loud ticking noise from the passenger front side of the engine like when you stick carboard into the spokes of your byicle as a kid.
And lots of blue smoke from the exhaust and there was hardly any oil left in it when checking by dipstick
diagnostics say its a imballance in cylinder 5???
any ideas please??? Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
No oil leaks that i can see
Post #574084 Tue Jan 29 2019 9:34pm
Autobiography1969
Hi I am not a mechanic but a quick search of the WWW gives this as a description..
your description shows as P0275 Cylinder 5 Contribution/Balance
"This is also a generic code, meaning it is common to all manufacturers.
The reference is the same, however, the manufacturer of a specific model may have experienced a defective part or error in installation.
Always access the technical service bulletins (TSBs) online for your specific year and make vehicle. Look for related TSBs and the factory recommended repair procedure.
The power-train control module (PCM) monitors the power output from each cylinder by comparing the acceleration or increase in speed of the crankshaft during the power stroke of each cylinder. When one or more cylinders are contributing less power than the rest of the cylinders, the fault code P0275 is set.
Not sure it helps other than a description of the error..
Good luck.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #574095 Wed Jan 30 2019 12:43am
I think you need to do a compression test on No.5 cylinder first, lots of blue smoke means burning oil, nearly empty sump confirms that, could be a number of things like possibly broken piston ring, worn valve guide, possibly turbo issue. Personally I would start with the compression test and work from there.
Post #574098 Wed Jan 30 2019 3:17am
HEFF
just had news from a garage. Censored need a new engine Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
i live in the north east durham,so i need a engine supplied n fitted cheap as poss
Post #574220 Fri Feb 01 2019 12:21pm
HEFF
they had found metal in my sump wich they say is bearings shell
Post #574432 Sun Feb 03 2019 4:55pm
You can get an engine from landrover for about £4K with 2 year warranty.
Swap bits over from yours.
Post #574437 Sun Feb 03 2019 5:50pm
HEFF
hi and thankd for the reply. will they fit as well ?
Post #574446 Sun Feb 03 2019 9:11pm
HEFF
how would i go about that
Post #574448 Sun Feb 03 2019 9:18pm
Talk to disco mike on D3
I guess you just walk into a dealer. And it arrives in a crate.
Swap over stuff and return old engine
Post #574455 Sun Feb 03 2019 9:50pm
Disco_Mikey
Pretty much
£4095 + VAT, plus a £2000 + VAT surcharge (refundable on return of old unit)
Usually, needs to be returned within 2 weeks
Post #574457 Sun Feb 03 2019 9:53pm
What service do you use to return old engine?
Post #574464 Sun Feb 03 2019 10:36pm
Disco_Mikey
The dealership delivery van?
Post #574466 Sun Feb 03 2019 11:02pm
HEFF
so £7k all in ?
blimey i only had the car 6 months. i got ripped off badly. such a shame im only a carer so my wages are not good
oh well.
thank you all for the replys. Thumbs Up
Post #574481 Mon Feb 04 2019 9:50am
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi there,
Sorry to hear your dilemma; might be worth having a read of this:
https://www.which.co.uk/consumer-rights/ad...-my-rights
The key bit being:
"During the first six months after purchase, it's the responsibility of the seller to prove the fault wasn't there, not for you to prove that it was. "
HTH
Post #574490 Mon Feb 04 2019 10:38am
HEFF
i bought it the car private and i got it just over 6 months ago, typical Big Cry
Post #574493 Mon Feb 04 2019 12:04pm
