![]() | Home > General > 2.7tdv6 funny loud tapping noise |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Hi I am not a mechanic but a quick search of the WWW gives this as a description..
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I think you need to do a compression test on No.5 cylinder first, lots of blue smoke means burning oil, nearly empty sump confirms that, could be a number of things like possibly broken piston ring, worn valve guide, possibly turbo issue. Personally I would start with the compression test and work from there.
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 ![]() ![]() ![]() |
just had news from a garage. |
they had found metal in my sump wich they say is bearings shell |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
You can get an engine from landrover for about £4K with 2 year warranty.
hi and thankd for the reply. will they fit as well ? |
how would i go about that |
Talk to disco mike on D3
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Pretty much
What service do you use to return old engine? |
The dealership delivery van? |
so £7k all in ?
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 ![]() ![]() ![]() |
Hi there,
i bought it the car private and i got it just over 6 months ago, typical |
