![]() | Home > Technical > Fairy Lights as DRLs L320 |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Fitting halo rings inside lights is easy. One you have removed the headlights, remove all additional parts attached. Then put headlight in oven at 190degrees for 3 minutes which will soften glue enough. Then prise open headlights, fit rings and ru wires from back of headlight. Then re attach glass etc and re fit headlights. Whole process takes between 1-2 hours, but results are well worth it Unfortunately its not possible to fit to 2010 onwards as they already have led lights ![]() |
