Home > Technical > Fairy Lights as DRLs L320
Bustanut
Been reading through these posts and I have ordered the patch leads today. I would like the lights to come on with the ignition instead of when the car is unlocked. Does anyone know if this is possible.
Post #574439 Sun Feb 03 2019 6:29pm
jason-nike
Tomascole1 wrote:
How easy was it to fit halo rings inside headlights
Fitting halo rings inside lights is easy.
One you have removed the headlights, remove all additional parts attached.
Then put headlight in oven at 190degrees for 3 minutes which will soften glue enough.
Then prise open headlights, fit rings and ru wires from back of headlight.
Then re attach glass etc and re fit headlights.
Whole process takes between 1-2 hours, but results are well worth it
Unfortunately its not possible to fit to 2010 onwards as they already have led lights
Post #574451 Sun Feb 03 2019 9:27pm
