Home > General > Low IQ and FLAMING LATCHES
RUSK
Hello again - all I have done since joining this (brilliant) forum is ask dumb questions about parts or faults for my 2008 L320... and this thread is exactly the same thing... sorry!
My passenger door lock sticks - the little square black piece inside doesn't close all the way when locked and doesn't open all the way when unlocked, the result being that the door is either locked when I need it open or open when I need it locked!
My garage say it just needs a "new latch" and I want to make sure I am supplying the right part...
Is this correct?
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...3856163069
Post #571891 Sat Dec 29 2018 12:51pm
Paddi
Considering the latches tend to become unreliable with age and are fiddly to replace I would advise against fitting a used part.
You can buy a new latch from advanced factors for not much more cash:
https://www.advancedfactors.co.uk/lr091527...7404-p.asp
As a forum member there is a small discount applied if you use the code they supply. 2008 MY Java Black TDV8 HSE
Post #571910 Sat Dec 29 2018 3:25pm
RUSK
That's brilliant - thank you... I will definitely go for the new item!
Post #571919 Sat Dec 29 2018 4:22pm
RUSK
What confuses me is the sheer volume of parts that >LOOK< identical, but probably aren't... the following (part numbers copied from the link above) appear on eBay as new parts, ranging from £20 up to £80 for what appears to be the same thing!
https://tinyurl.com/RANGIEPARTS1
https://tinyurl.com/RANGIEPARTS2
https://tinyurl.com/RANGIEPARTS3
Post #571920 Sat Dec 29 2018 4:36pm
yeah if you going to have the fun job or fitting it yourself, a cheaper part maybe the way to go.
But if your paying garage labour rates, it maybe worth paying extra IMO
Post #571934 Sat Dec 29 2018 6:18pm
RUSK
It looks very much like the only differences are the price - I think I'll play it safe with the OEM in the first link, it'll be thgarage doing the fiddling for me...
Post #571936 Sat Dec 29 2018 6:27pm
