Home > Technical > Indicator
Tomascole1
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Indicator
I have noticed something really odd whilst I indicate left for some reason my full beam comes on the same time? Any ideas
Post #571645 Mon Dec 24 2018 10:12am
TubaPlayer
Are you sure it's the full beam? It is more likely to be the cornering light (it has a separate bulb in the headlight unit) 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571651 Mon Dec 24 2018 10:28am
there's a bulb in the reflector below the indicator
for corning
Post #571652 Mon Dec 24 2018 10:30am
Tomascole1
No it's definetly full beam I have the blue full beam light appear on the dash
Post #571653 Mon Dec 24 2018 10:31am
probably faulting indicator stalk then as an easy and cheap attempt to fix
Post #571660 Mon Dec 24 2018 11:17am
Brit Plumber
Does the full beam come on with the Baz lights? If not I’d go with stalk to. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #571682 Mon Dec 24 2018 8:24pm
Tomascole1
The with baz?
Post #571689 Mon Dec 24 2018 9:36pm
Brit Plumber
Bloody auto correct.... Hazard lights 2019 5.0 SC SVA (Current)
Post #571691 Mon Dec 24 2018 9:48pm
Tomascole1
No just indicating left it's strange
Post #571694 Mon Dec 24 2018 10:00pm
Tomascole1
How hard is it to change an indicator stalk??
Post #571695 Mon Dec 24 2018 10:00pm
Brit Plumber
Before you do look at changing that, maybe try disconnecting the left front indicator and see if the full beam comes on still, then repeat with the rear and then the door repeater just to rule out a bad earth (although I suspect only the front left if any, would effect full beam).
Does full beam flash or just come on and stay on? 2019 5.0 SC SVA (Current)
Post #571700 Mon Dec 24 2018 11:41pm
Tomascole1
It's strange because when I put full beam on it doesn't seen to click on if you know what I mean is it supposed to? Merry Xmas to all by the way
Post #571703 Tue Dec 25 2018 8:13am
well if the stalk doesn't feel right, and indent onto main beam, that is a good reason to change it
Post #571711 Tue Dec 25 2018 11:11am
Tomascole1
So there's supposed to be an indent into it??
Post #571713 Tue Dec 25 2018 11:16am
your meant to push the stalk back (to the dash board) and it stay there in main beam mode, just like 1970's cars.
You then pull it forwards (to steering wheel) for normal dip.
A pull forward gives a momentary flash and it should return to center
Post #571715 Tue Dec 25 2018 11:39am
