Home > In Car Electronics > Touch Screen Issues
Eaters
Touch Screen Issues
My RRS has an intermittent problem with the Nav Screen. At its worst its impossible to read (see video )
Sometimes it appears OK but the "Agree" button doesn't work so you can't get to the maps. And sometimes it all works perfectly. Any ideas? Would a new map disc sort it? It appears to be something to do with the boot up of the system. Does the disc have any boot up instructions on it that could be corrupted??? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #571180 Sun Dec 16 2018 12:52pm
If the 4x4 info display also has the problem, then you need a new display unit.
If its only the Nav that has the problem, then check the video cable between the display (connector on passenger side) to under the passenger seat. (you can see the connector from the back seat)
Post #571200 Sun Dec 16 2018 3:57pm
Bill Portland
Definitely looks like a hardware or wiring problem, a new satnav disc won't fix that.
Worth checking out the wiring and connections are all solid. Merc C220 estate Sport AMG
Merc C220 estate Sport AMG 125 year edition
Alfa GT
Rover 76 V6
Post #571217 Sun Dec 16 2018 6:46pm
Eaters
Thank for the thoughts guys. I'm away for a bit but will have a look when I get back Robin
Gone:
MGZTT 190 2.5
Post #571257 Mon Dec 17 2018 12:25pm
