![]() | Home > Tips & Tricks > Hiccup... cured with IID.?? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I went to start up my 2005 TDV6 last night and it took 2 attempts! Very unlike her. Then the red airbag warning light came on and stayed on for the short return journey I had to make.
Thanks Cu11eyx, unlikely though. The temperature here was not that low and the battery is good. No other issues since the reset. Barrie.
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Give the battery a nice full charge with CTEK or similar.
Socketuser Member Since: 23 Oct 2018 Location: Preston Posts: 7 ![]() ![]() ![]() |
I believe with some cars the ecu can memorize the charge in the battery had. Therefore when the car is running it will only charge it back up to the last memory of the batteries power. This can be remedied by taking the battery off charging fully then replacing on the car hence the memory will be full and the vehicle will recharge it up to this level.
