Home > Faults & Fixes > Flickering led
Graham Ives
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Flickering led
Hi guys I've noticed this morning I have a led flickering in the rear light cluster is it a case of new back light live with it or can it be fixed any advice be great Rrs sport 2012 Orkney grey
Post #570216 Fri Nov 30 2018 6:32pm
RRSREDBLACKEDDIE
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
I have the same problem. I see nobody replied. Can’t find much on this subject anywhere so must be a rare problem or no fix unfortunately that none can explain a fix?
Post #629241 Sun Dec 18 2022 5:55pm
TheWojtek
A flickering LED is an indication of the diode going bust. There is no fixing to light-emitting diodes, you replace them. It is possible to open the assembly and replace a single unit, but it takes a skilled solderer and careful choice of the replacement element. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #629242 Sun Dec 18 2022 7:24pm
RRSREDBLACKEDDIE
Yep I thought so .. thanks for confirming. RRS HSE 3.0TDV6 RED EDITION
22” OEM MATT BLACK ALLOYS
Post #629248 Sun Dec 18 2022 10:59pm
Meiang
My tachometer needle sometimes flickers on startup which only lasts for a minute or two. Its being doing this for a few years now. As it does not last very long I can live with it, rather than have my instrument cluster pulled apart with the squeaks and rattles which would result.
Post #629290 Tue Dec 20 2022 3:54am
