Home > Maintenance & Modifications > is this oil any good
PC76
Hi All,
with my service due in under 1500 miles i thought i would look around for some oil... and driving what now appears to be circa 25k miles a year (30k last year and 20k the previous) I thought i might buy in bulk....
with the "black friday" deals being touted around I found this on eurocar parts...
Shell Engine Oil (Helix Ultra Professional AF 5W-30 Engine Oil - 20ltr)
all for £45 delivered... is it any good?
Post #569619 Sat Nov 24 2018 12:01pm
just make sure its the correct C3 or whatever is required
and how to get the oil out of the 20l container. hand pump ?
20; is a sensible amount to buy
Post #569620 Sat Nov 24 2018 12:20pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Second comment on oil in an hour!!!
Does you car have a DPF? if so this oil is wrong for your car as it's A5 B5 The handbook will specify the grade you need so check it matches the oil. If you do have a DPF you need SHELL HELIX ULTRA AF-L 5W-30 C1.
That said I have never seen it at that price, but a new engine is a lot more.
Post #569631 Sat Nov 24 2018 3:13pm
removed
Post #569635 Sat Nov 24 2018 3:47pm
PC76
I have the 2010 3.0 TDV6 so no DPF.
Will check with them on the spec as can’t see it on n the picture..
Post #569641 Sat Nov 24 2018 6:42pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Re: is this oil any good
PC76 wrote:
Hi All,
That is the exact oil RR gave to me to put in my 3.0 2011 tdv6 so I think you should buy at that price Thumbs Up Thumbs Up
Post #569654 Sat Nov 24 2018 8:29pm
LandPhil
With no DPF that oil is good - A5. Thumbs Up
We’ll done, good find.
Post #569660 Sat Nov 24 2018 8:50pm
knwatkins
Are you sure? I have a 2010 TDV6 and mine has a DPF.
The spec for mine is ACEA C1 to spec WSS-M2C934-B
Post #569665 Sat Nov 24 2018 10:21pm
LandPhil
IIRC they were an option in 2010 and fitted as standard in 2011.
Post #569666 Sat Nov 24 2018 10:46pm
PC76 wrote:
Hi All,
Helix Ultra Professional AF 5W-30 Engine Oil AF matches 5W/30 WSS-M2C913-B or C non DPF
Helix AF-L matches 5W/30 WSS-M2C934-B with DPF
Post #569680 Sun Nov 25 2018 3:08am
