![]() | Home > General (L494) > Extended Warranty Handbook - Crankshaft |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4457 ![]() ![]() ![]() |
But it doesn't cover "known issues" or "design flaws" which they both relate to crank failure, as JLR released a TSB about it... |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Thanks for the reply mate, does it say that in the hand book anywhere?
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Technical service bulletin
Nowaytk Member Since: 27 May 2013 Location: London Posts: 183 ![]() ![]() |
When mine went I had the extended warranty, and it was only the horror stories on here that made me a bit paranoid, some were saying it’s definitely NOT covered and it was only a good will payment LR gave out to some. What didn’t help was that it only mentioned that the crank is covered in the SELECT extended warranty with no mention in the extended ? 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
The proof is here in clause 11:
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The manufacturer hasn't recalled the crankshaft though. And whether it's an inherent design fault is open to interpretation - LR say there's nothing wrong with it.
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
Does anyone have any stats for crankshaft failure - ie. what % of vehicles have suffered?
Did they cover yours? Or was it a LR good will payment? John |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
Would be interesting to know - like you say you could be put off buying anything from reading the internet. You could be put off even leaving the house! There's circa 25k RRS SDV6's on the UK roads at the moment. MY16 RRS 3.0 SDV6 HSE Dynamic |
MrMeg Member Since: 05 Nov 2018 Location: Essex Posts: 37 ![]() ![]() ![]() |
I think the horror stories are always overlooked or pull at out worrying side, I think the car crank cant be a total worry or the used prices on these would reflect the huge issue.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
But they HAVE recalled them in S Korea. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
But not in the UK. 2012 SDV6 - it's missing a couple of cylinders
There are so many RRS around I do wonder how many as a percentage this actually has affected. I see so many I literally passed 3 on my lunch break today./ Although makes my car seem a lot less special |
I'll say it again
