Home > General > Non OEM brakes & Extended Warranty |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Ask the main dealer the question. This is not for someone else to have a guess at. Also check what is covered as the extended warranty is not the same as the manufacturers warranty. Some things are not covered. |
Mon Oct 08 2018 8:05am |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 |
All the dealer will say is "all claims will be rejected" as they will want the business; I was hoping others may have been in a similar situation before & I might benefit from their experiences. |
Mon Oct 08 2018 8:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Would have thought it highly unlikely discs and pads would be covered under warranty anyway as these would be considered wear and tear items, mind you L/R might use it as a excuse if there was a problem with another part of the brake system.
Mon Oct 08 2018 8:43am |
Looks like you have your answer "all claims will be rejected" after all, its them who you will have to take the car back to for warranty |
Mon Oct 08 2018 8:55am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Does it really need new discs! What mileage has it done? |
Mon Oct 08 2018 11:02am |
44,000 miles; I have just checked the discs and all four have a lip on the outer edge - perhaps 1-2mm - so presume they do need changing. |
Mon Oct 08 2018 12:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
It won't affect the warranty because brake pads and dsics are covered by it anyway. The calipers are but the make of pad / disc won't affect these anyway. 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 08 2018 5:01pm |
