Home > Faults & Fixes > Engine running cooler
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Now I know the outside temp has dropped all of a sudden and I don't drive the RRSS very often but today I noticed that the engine took longer to get up to temp. The LPG didn't come on as early too. And the temp gauge is slightly below half way when it has always been dead on half.
Thermostat stuck open? What do you reckon..
Post #566021 Sat Sep 29 2018 9:25am
geoffsnook
Rubber seal on the thermostat distort's just changed mine much better now Thumbs Up
Post #566045 Sat Sep 29 2018 6:42pm
Themoog
Yes I did a bit of research online and that seemed to be the common fault. Thanks.
Post #566051 Sat Sep 29 2018 8:30pm
geoffsnook
Was on mine now once again once I have driven about half a mile mine switches to gas again where it was taking a lot longer before I changed it:thumbsup:
Post #566054 Sat Sep 29 2018 8:48pm
Themoog
Replaced the thermostat about an hour ago. Only when I took it out I realised I had no new big o ring for the housing. Fingers crossed my sealant will be ok..
And true to form the old stat had the rubber bit all ripped and falling off the centre part.
Post #567449 Mon Oct 22 2018 2:29pm
geoffsnook
Post #567466 Mon Oct 22 2018 5:33pm
Themoog
By the way.. When I removed the plastic air intake I had to unclip a small pipe on the right side. On the left there is a alloy pipe end with a big Allen head bolt on the top of it- it has no pipe connected to it. Any idea what it is or was for? It's just to the left of the ally air intake hole.
Post #567492 Tue Oct 23 2018 5:16am
