Home > In Car Electronics > Base stereo front speaker not working
jordanl5183
Hi all,
I have an issue with my drivers door speaker not working (no sound, but all others are fine). I have the base audio system, which is ok, but not great. I just wondered if there was a way to test if the speaker is bust or if it's a wiring issue.
If the speaker is a goner, does anybody know the part number for it or of any aftermarket ones that would be easy enough to fit?
Thanks,
Jordan
Post #565813 Mon Sep 24 2018 3:48pm
Not really base system. It has an amp user seat
On mine if I crank the volume up high I’d starts and continues working.
I found green speaker wires touching at seat mounts but it didn’t fix it!
Post #565816 Mon Sep 24 2018 5:09pm
jordanl5183
Thanks for the response Andy. So you're saying that the non HK system has an amp under the seat?
Post #565843 Tue Sep 25 2018 3:43pm
A UK HSE should have a HK system. With HK on the speaker grills.
The petrols had the HK logic7 system.
Post #565845 Tue Sep 25 2018 4:55pm
jordanl5183
Yeah it's a funny one, despite being an HSE, no navigation and the build sheet says it didn't have the HK system. The speakers just say land rover on the grille on the door.
Post #565847 Tue Sep 25 2018 5:17pm
