![]() | Home > Technical > Rear Diff Delight |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
The photos aren't too clear where that leak is from. Are you saying it's from the drain Plug?
JordLMW Member Since: 13 Nov 2017 Location: Lincolnshire Posts: 25 ![]() ![]() ![]() |
From inside this hole, if it was a drain plug why would it be on top?
The orientation of the photos isn't clear.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
If it's a drain/fill plug, you need to check if the thread has been cross-threaded. If it is, can you not get a helicoil insert (screw threaded insert) put in as a permanent repair? Assuming people still do them. I would suggest that the supplying garage should be able to do for not a lot of cost to them. |
Why does it look like that boss has had a repair around the outside of it? 2019 5.0 SC SVA (Current)
Yep.. see that now.
What year RR Sport do you have? Looking for drain plugs... 2011 MY D4 HSE
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9023 ![]() ![]() ![]() |
If it's on the top, it's not a drain, it's the breather. There should be a pipe connected to it that runs up to the back of the fuel filler inlet. The pipe would connect to a spigot on top of that breather location. Looks like someone has done a full on bodge job on that diff. The drain plug, just visible in the bottom picture, looks to be corroded up. Guessing that someone has tried to use the breather to empty/fill the diff somehow. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Scrap that, if that's on the side next to the rear prop shaft and you have the locking rear diff (you have a HST I see), then that is the location that should have had a damper mass attached to it. The damper mass is hexagonally shaped and I bet someone has tried to "open it", and sheared it off.
Thanks for the replies guys, yes it's a TDV8 HST 2008 model. I'm not happy at all to be honest. I believe it has just been bodged by the garage and that they are responsible for it but I'm not sure what to do. I think I'm going to take it to a landrover specialist and see if they can have a quick look and give an opinion. What's worrying is that this has all been diagnosed and repaired by a land Rover "Technician" from the stealership I bought it from.
Oh and to add I got told it holds a pin with a spring of some sort for the locking diff? Is this correct or am I being spun some more tripe. |
Total tripe. The locking diff uses the motor on the top of the diff to make it lock. Short description: a motor rotates a pair of discs that have balls sat in ramps. The ramps cause the plates either side (that have the balls sandwiched between them) to move sideways. The sideways movement creates a force that pushes the locking plates in the diff together. The exact same system is used in the centre diff. The bit that would have fitted in the hole you have there is a tuned mass damper. It's entirely passive and has nothing to do to with the operation of the diff.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
It's not leaking from the ARC bar onto the diff casing, is it? |
