Home > Technical > Transmission Fault- Traction Reduced.., familiar?
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
I keep getting "transmission fault, traction reduced" displayed intermittently at start-up (every 3rd/4th day). It extinguishes, but apparently doesn't record on the diagnostics? The dealer tried uploading new transmission software but that wasn't successful and the "ghost" fault still continues.
Has anybody else experienced this problem or got any suggestions please? Those infernal bongs are getting to me!!! Banging Head Banging Head Banging Head
Post #79399 Thu Feb 01 2007 12:04pm
Hmm, this has come and gone a few times, this error. Normally one of those that occurs and then doesn't rear it's ugly bits for several months. You could always take the MDP route and replace the battery too... Very Happy
Post #79428 Thu Feb 01 2007 12:48pm
Lateral5
Australia
shmoogle wrote:
....You could always take the MDP route and replace the battery too... Very Happy
Or the car.......! Wink RRS TDV6 Bluetooth, VR, Roof
Post #79433 Thu Feb 01 2007 12:53pm
A bit drastic, but it would certainly cure the problem! Wink
Post #79438 Thu Feb 01 2007 1:00pm
Brian Mason
Yeah, and no more sleepless nights! Smile
Post #79442 Thu Feb 01 2007 1:02pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
It could be low battery voltage? The only time I saw that message was after bringing my car at a tyre shop to switch wheels. The mechanic left the key in the ignition and the headlights were on the entire time while the car was on the lift. When he was done and I restarted the engine, that message (and related "bong") popped up for a couple of seconds, then went away. I never saw it again. Get your battery checked. Either that, or something in your car may be malfunctioning and/or draining the battery overnight.
Post #79492 Thu Feb 01 2007 4:11pm
landroverstormer
England 2006 Range Rover Sport TDV8 HSE Java Black
I'm almost certain it will be either a loose terminal (check first) or a gel battery that has been discharged at some point in its life. Before changing the battery it's worth asking the dealer to trickle charge with a specific charge for gel.
Good luck! Rolling Eyes TDV8 HSE in Java/Ebony with Zebrano Wood, RSE, Hybrid TV, and a few other bells and whistles.
Discovery 1 V8i Auto (The Off Road Toy)
Post #79618 Thu Feb 01 2007 8:36pm
Brian Mason
Thanks LRS. The car's come back from the garage today without anything having been done..., apart from head-scratching! Therefore, I'll pass on your suggestion tomorrow! Thumbs Up
Post #79619 Thu Feb 01 2007 8:42pm
