![]() | Home > General (L494) > Water collecting in tailgate |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Anyone else had this issue? Both corners of the tailgate drip water when opened nearly all the time. It’s obviously been a problem forever as there is a lime trail on the plastic. Reckon I’d have a stalactite if I left it any longer. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Mine does this too. I assumed it was normal like when water drains out of doors and from the sunroof drains too....isn`t that why the holes are there (tailgate ones)? Steve. |
Big Al. Member Since: 06 Feb 2018 Location: Dorset Posts: 5 ![]() ![]() ![]() |
Had the same problem on mine, it appeared to be water ingression via the holes under the number plate. Holes plugged problem resolved. RRS 2016 3.6V6 D. Autobiography Dynamic
Thanks all, will have a poke about Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Hyperhatch Member Since: 16 Jul 2018 Location: Hampshire UK Posts: 5 ![]() ![]() |
My 2018 SVR did this from new! The spoiler was misaligned in the SVO workshop. Body shop removed and refitted (it was squeaking as it opened due to the same spoiler mismount rubbing) and is now fine. |
