Home > Technical > Replacing 2.7 TDV Range Rover engine with Jaguar S-Type
florianu
Romania
Hello to all
Does anybody can detail what are needed changes to be made in order to replace 2.7 TDV Range Rover engine with Jaguar S-Type?
From what I have understand after my research we have following:
-upper oil sump to be replaced from RRS engine
-lower oil sump to be replaced from RRS engine
-crossover pipe from left to right turbo to be added from RRS engine
-some pipes with different routing taken from RRS engine
Any other?
I apologize if there is any other similar topic...which I did not found.
Tanks in advance
Post #564923 Mon Sep 10 2018 1:15pm
Strip ancillarys down as much as possible and fit LR items.
Remove 2 jag Turbo's
Fit 1 LR turbo
Change dip stick tube
Best to Change injectors over if they will come out easily.
Fit LR fan
Post #564928 Mon Sep 10 2018 2:07pm
https://www.disco3.co.uk/forum/2-7-tdv6-en...53207.html
https://www.disco3.co.uk/forum/engine-body-procedures-158296.html
Post #564948 Mon Sep 10 2018 5:10pm
Disco_Mikey
Everything is different
Crankcase
Sump
Dipstick
Manifolds
Turbo/s (and oil feed and drains)
Breather system
Injectors and fuel rails
Cooling system
Vacuum pump
Wiring harness
Timing belt cover
Viscous fan hub
HPFP + EGR valves are model dependant
Engine mounts
PAS pump + AC pump mounts
Everything Thumbs Up
Post #564952 Mon Sep 10 2018 6:30pm
florianu
Romania
Fit 1 LR turbo
Fit LR fan
thanks for a short and comprehensive answer
Post #564983 Tue Sep 11 2018 6:28am
florianu
Romania
Crankcase
Sump
Dipstick
Manifolds
Breather system
Cooling system
Vacuum pump
Wiring harness
Timing belt cover
Viscous fan hub
Engine mounts
for sure timing belt cover will make the difference...
what about engine completely stripped - what's the difference then?
Post #564985 Tue Sep 11 2018 6:31am
florianu
Romania
did it. RRS is live again Smile
only kept injectors
happy to help with advices
Post #569023 Thu Nov 15 2018 2:12pm
Post #569035 Thu Nov 15 2018 5:10pm
