![]() | Home > General > Battery replacement advice needed - 2011 RRS |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
Euro and put the reg number in and you will have a choice of brands |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Done that, also get a choice of batteries - C17, C19 and C20! Which one is preferred? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I used a Varta G14 AGM Stop Start battery. Came from Tanya Batteries delivered next day. The 020 will not fit it's to long 393mm as opposed to 353mm, unless battery box and wiring is modified slightly. 017 and 019 are same dimensions so both will fit, not sure of the rating of each, though imagine 019 is slightly higher Ah and CCA and possibly terminal height lower on 017 depending on manufacturer.
Thanks for the advice
Personally I would go for the highest rated one I could get in.
Thanks mate,
No, disconnect Negative first and reconnect last, nothing else to worry about but bare in mind the battery is quite heavy and relatively tight fit, move leads well out of way first.
Thanks mate |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
What ever you do DO NOT BUY A LION BATTERY!!!
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
As your RRS is a 2011 model it may have a battery monitoring system - A lot of markets had a BMS from 2010 onwards. I was under the impression that this needs to be reset when changing the type of battery or putting in a battery of different capacity and if you don't the charging system starts doing funny stuff. |
Never reset mine and never made a blind bit of difference, if you do reset it would suggest you make sure battery is fully charged first.
The battery in my 2010 TDV8 is a AGM 95Ah unit with 850CCA. |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
I made one of this, made replacement much easier |
Not quite sure that would work on a sport as the battery is in a different position to the fullfat. The position of your wooden plank is directly over the battery on a sport as it is.
