![]() | Home > In Car Electronics > Sat nav stopped working - "no nav available" messa |
Yorkie09 Member Since: 15 Aug 2018 Location: Braintree Posts: 7 ![]() ![]() ![]() |
Sat nav was working fine, wife cleaning behind passenger seat and disturbed the retro fitted multimedia Video Interface Unit, now have "no nav available" message on screen. Have run 753 diagnostic and it reports DTC U1A0131 GVIF Signal Fault.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Check the GVIF IN OUT connectors.
It doesn't look possible to insert the connector upside down?, I disconnected it and reinserted it the same way.
The blue connector that goes into the rear of the nav unit itself can go in upside down if you disturbed that one as well |
The no nav message appeared before I removed any of the connectors, was working fine before the MM interface unit was disturbed. |
Fantom Sport Member Since: 27 Feb 2021 Location: Surfleet Posts: 8 ![]() ![]() ![]() |
Did you fix the problem. Mine says exactly the same after removing my Radio and touching the interface box. |
