Home > In Car Electronics > Sat nav stopped working - "no nav available" messa
Yorkie09
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
Sat nav was working fine, wife cleaning behind passenger seat and disturbed the retro fitted multimedia Video Interface Unit, now have "no nav available" message on screen. Have run 753 diagnostic and it reports DTC U1A0131 GVIF Signal Fault.
Having looked at the jumble of wiring (by previous owner), it looks as though the factory nav system doesn't run through the MM Interface unit, so what is the problem with the system? Have disconnected and reconnected connectors to rear of nav DVD drive but no change, system dials register the nav DVD but cannot initiate the nav system. Help!
Post #563289 Wed Aug 15 2018 7:43pm
Check the GVIF IN OUT connectors.
Do NOT turn Them upside down else further confusion!
Post #563297 Wed Aug 15 2018 9:31pm
Yorkie09
It doesn't look possible to insert the connector upside down?, I disconnected it and reinserted it the same way.
Post #563325 Thu Aug 16 2018 10:44am
The other end of that black cable.
Check its plugged in.
Does your DVD player, or whatever you use that GVIF for display on the screen still ?
Post #563328 Thu Aug 16 2018 11:05am
geoffsnook
The blue connector that goes into the rear of the nav unit itself can go in upside down if you disturbed that one as well Thumbs Up
Post #563340 Thu Aug 16 2018 3:06pm
Yorkie09
The no nav message appeared before I removed any of the connectors, was working fine before the MM interface unit was disturbed.
Post #563348 Thu Aug 16 2018 5:43pm
Fantom Sport
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
Did you fix the problem. Mine says exactly the same after removing my Radio and touching the interface box.
Post #612803 Mon Apr 19 2021 7:52pm
