Home > In Car Electronics > Sat-nav, Bluetooth and Stereo has stopped working
davecg69
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
This morning I took my RRS out and everything was working perfectly. Later, when I went out again, the Sat-nav just says “initialising”, the Bluetooth won’t find my phone (annoying as I get quite a few calls when driving) and the audio system is just greyed out and not working at all.
Before I call the dealer, I was wondering if there’s a fix (though I suspect I’ll be told to disconnect the battery and do a hard reset)?
Is this a common issue? My RRS is a 2012 HSE SDV6, but, to be honest, I’m considering changing it now as it’s beginning to get a tad expensive to maintain. Big Cry
Post #562819 Tue Aug 07 2018 4:36pm
Andyjay123
How much have you spent so far and how long have you owned it? I love the sports 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562820 Tue Aug 07 2018 4:37pm
Bill Portland
Have you turned it off and on again? Merc C220 estate Sport AMG
Merc C220 estate Sport AMG 125 year edition
Alfa GT
Rover 76 V6
Post #562823 Tue Aug 07 2018 4:53pm
davecg69
Repeatedly .. Laughing
Post #562824 Tue Aug 07 2018 4:55pm
Father Jack
Hard reset ? Disconnect cables from battery and touch together ? Search the site for precise how to but may be worth a try ?
Post #562835 Tue Aug 07 2018 7:27pm
Any devices plugged in to USB ports? I had similar symptoms when a USB stick played up. The stick got very, very, hot. Removing the stick sorted it all out in a jiffy. 2012 SDV6 - it's missing a couple of cylinders
Post #562847 Tue Aug 07 2018 9:23pm
davecg69
Thanks. I saw the earlier thread and tried taking the usb stick out, but no luck.
I’ll see if it’s the same tomorrow and then try a hard reset, if I’m brave enough!
Post #562848 Tue Aug 07 2018 9:25pm
davecg69
Started her up this morning and all ok, with me doing absolutely nothing.
So .... intermittent fault? Can’t be a fuse as that would take it all out, wouldn’t it? An annoying glitch. Anyone something similar?
Thanks to all for your thoughts - I’ve had her since 2015, regularly serviced, new tyres all round, repaired some leather on seats, so not too much spent yet, but I have an idea the service charges will continue to increase, etc. I love her, but not as much as my Discovery Smile
Post #562887 Wed Aug 08 2018 1:48pm
Bill Portland
the reason i asked if you'd turned it off and on again was that it happened to me once, a few months ago and all I had to do was stop, turn everything off and on again. I put it down to a glitch when booting up. It hasn't happened again.
Yours sounds like something more sinister if you tried several times. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #562888 Wed Aug 08 2018 1:56pm
davecg69
Thanks, Bill. Yes, I’m worried that it is! Might have to go down the dreaded “dealer route” Big Cry
Post #562895 Wed Aug 08 2018 3:33pm
Could be a slightly loose earth somewhere. There are a few easy-to-reach ones in the engine bay that it would be worth checking at least. Others lurk behind trim and underneath. 2012 SDV6 - it's missing a couple of cylinders
Post #562899 Wed Aug 08 2018 4:23pm
