Home > In Car Electronics > Towing reverse sensors
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
I towed for the first time with my sport today and when I select reverse when caravan connected the sensors were bleeping
When I towed with my old sport the sensors turned off when caravan was connected
I think the wiring kit is factory as the sockets were plastic filled on reverse where the wires connected
Any ideas please
Cosmo
Post #562140 Fri Jul 27 2018 5:49pm
Brit Plumber
You need the IID tool to select the correct setting in the file. With the correct setting selected, it will detect a trailer and turn off the rear PDC. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #562145 Fri Jul 27 2018 6:31pm
Cosmo15555
I have iidtool I think I selected the towing section I will check
Is there something else I need to turn on
Post #562167 Fri Jul 27 2018 8:19pm
There are about 7 tow configure options.
You will have fun finding the correct one. If you could then let the dealers know the correct one. Wink
Post #562176 Fri Jul 27 2018 9:34pm
maybe worth a read and useful links
https://www.disco3.co.uk/forum/tow-electrics-help-173544.html
Post #562225 Sat Jul 28 2018 4:12pm
Cosmo15555
I have changed the setting from undefined to 13 pin socket and now the sensors don’t bleep when caravan is connected
Strange thing is to enable the sensors after towing I have to switch the ignition off then back on again
Thanks for the replies
Cosmo
Post #562231 Sat Jul 28 2018 5:34pm
