Home > Maintenance & Modifications > Alignment!!????!??!?!?!?! help me |
Wow what a cop out they obviously don't have a clue stay far away from then |
Mon Jul 23 2018 4:50pm |
Who the uses kwik fit jokers anyway? Steve. |
Mon Jul 23 2018 6:06pm |
I thought it was quick they are good for a re-gas for£49 |
Mon Jul 23 2018 6:44pm |
I wouldn`t use them for even that! Steve. |
Mon Jul 23 2018 7:32pm |
But you get a re-has if it don’t work so worth it to find a leak |
Mon Jul 23 2018 7:45pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
I had all this, ended up at the stealers after all the indies were flaking. I can't remember what it cost. Couple of hundred quid maybe. They gave me a free car for the day to play in as well. It came back washed and vac'd too. About the only thing worth using the stealer for I noted at the time. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car. Spiffing wheel centre caps available |
Mon Jul 23 2018 8:22pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Hunter Alignment Centres
Tue Jul 24 2018 6:55am |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
200 quid for alignment is excessive. Paid 50 quid at an indy specialist. Col's link will locate a good spread of options. |
Tue Jul 24 2018 6:58am |
As a reference I paid £60 for mine to be done. Steve. |
Tue Jul 24 2018 9:38am |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 |
Phoned Land Rover who stupidly told me where they get theirs done. Paid £84 and they sorted it however check out how far the steering is out. The photo shows me driving in a straight line
Wed Jul 25 2018 5:45pm |
Take it back and tell them the steering is not right they should have set it in the straight ahead position |
Wed Jul 25 2018 6:02pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I use my local indie (not much good to you) but look for body repair specialists locally as they must be able to straighten a crash damaged car so should have the right equipment. My local one charged me £85 for 4 wheel alignment. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Wed Jul 25 2018 6:52pm |
The garage who did the wheel alignment or the garage i purchased the car from 2 weeks ago? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Wed Jul 25 2018 8:07pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
toe-setting: RF 1/4 turn out,LF 1/4 turn in, and your steer is probably right in the middle without effecting the alignment settings. RRS 3.0 SDV6 HSE Lux
Wed Jul 25 2018 9:12pm |
