![]() | Home > Maintenance & Modifications > Alignment!!????!??!?!?!?! help me |
Wow what a cop out they obviously don't have a clue stay far away from then |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Who the |
I thought it was quick |
I wouldn`t use them for even that! Steve. |
But you get a re-has if it don’t work so worth it to find a leak |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I had all this, ended up at the stealers after all the indies were flaking. I can't remember what it cost. Couple of hundred quid maybe. They gave me a free car for the day to play in as well. It came back washed and vac'd too. About the only thing worth using the stealer for I noted at the time. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car. Spiffing wheel centre caps available |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Hunter Alignment Centres
200 quid for alignment is excessive. Paid 50 quid at an indy specialist. Col's link will locate a good spread of options. |
As a reference I paid £60 for mine to be done. Steve. |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Phoned Land Rover who stupidly told me where they get theirs done. Paid £84 and they sorted it however check out how far the steering is out. The photo shows me driving in a straight line
Take it back and tell them the steering is not right they should have set it in the straight ahead position |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I use my local indie (not much good to you) but look for body repair specialists locally as they must be able to straighten a crash damaged car so should have the right equipment. My local one charged me £85 for 4 wheel alignment. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
The garage who did the wheel alignment or the garage i purchased the car from 2 weeks ago? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
toe-setting: RF 1/4 turn out,LF 1/4 turn in, and your steer is probably right in the middle without effecting the alignment settings. RRS 3.0 SDV6 HSE Lux
