Home > In Car Electronics > Parking sensor fault ‘06 supercharged
LJRH
Hi guys,
My sensors seem to have stopped working. On ignition there is a constant tone beep for around 3 seconds but while driving, although the light is illuminated, they’re not working.
When I turn the ignition off, the light flashes. There are no warning messages and no other warning lights. Any ideas? Noisy black one
Post #561494 Tue Jul 17 2018 1:02pm
Cymruambyth
Wales
Mine are the opposite, as soon as I select reverse they go mental so I just turn them off now. Steve.
Post #561501 Tue Jul 17 2018 5:03pm
geoffsnook
Either a faulty sensor or a chaffing wire usually Thumbs Up
Post #561503 Tue Jul 17 2018 5:23pm
LJRH
Grrr sounds expensive Noisy black one
Post #561507 Tue Jul 17 2018 5:47pm
geoffsnook
Sensors are between £10 and £30 on the bay and if the bumper is off takes about an hour-2 hours to get off so not really hard to be honest Thumbs Up
Post #561508 Tue Jul 17 2018 5:54pm
Packard66
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
how to check which sensor is not working?
Post #564470 Tue Sep 04 2018 11:57am
reading the fault codes is best.
Post #564475 Tue Sep 04 2018 4:53pm
Signori
Did you find a fix for this? Mine have decided to start doing this. Put in reverse just a long tone that lasts forever. Then when you change to drive they just beep and go crazy even when theres nothing around
Post #567319 Sat Oct 20 2018 10:43am
Rangey Davey
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Java Black
I had two sensors that were not working, one on the front one on the back. I found which ones by putting my ear right up to each sensor in turn and listening for a ticking which tells you that it’s working. Managed to replace both sensors of eBay and without totally removing bumpers just loosening them and getting my hand in!
Post #567633 Thu Oct 25 2018 2:49pm
Signori
Awesome thanks, i'll try that. Do you just need to engine on for it? Or does it need to be in reverse?
Post #567634 Thu Oct 25 2018 2:52pm
Rangey Davey
No need for engine as it’s quieter. Ignition on and in reverse, I think I had to put a brick under the wheels and take the handbrake off.
Post #567635 Thu Oct 25 2018 2:59pm
