![]() | Home > Off Topic - Other Cars > Focus rolled away |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
And I thought Lincolnshire was flat! |
Used to panic about the same with my Fabia VRS
It’s booked in for a check up on Saturday. It’s only done 4000 miles so I doubt they will find anything wrong. 2019 5.0 SC SVA (Current)
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 ![]() ![]() |
Maybe a few of the teeth on the ratchet part of the handbrake lever are worn. When you pull it up 5-7 clicks, give it a wiggle, Often it will jump down a tooth and thats enough for it to roll away.
Put a couple of big stones or bricks behind the wheels as a back up, I do that to all my cars when I go to sea, just in case. On one occasion it also delayed a would be thief long enough for plod to catch him red-handed trying to figure out why the car wouldn’t move backwards! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
This is why older Saabs wouldn't let they keys be removed from the ignition unless the gearbox was in reverse. |
