Home > Off Topic - Other Cars > Focus rolled away
Brit Plumber
Focus rolled away
You know when someone says something you dismiss as being Censored ? Well my lad is the best at it and has lots of practice too but when he looks out of the Kitchen window and says ‘someone’s stealing our car’, that’s not the normal Censored he spouts and I think I should check it out. I ran to the back door to find it locked, took an eternity to unlock it and got out to see the car backing off the drive. As I ran to the car it stopped on the neighbours drive over the road but........there was no one in it. To top it off the doors were locked and I could see the handbrake was on. The wife brought me the keys and I unlocked the car. I managed to get two extra clicks on the handbrake ratchet and after some experimenting I found there are 7 clicks from off to on. I put 5 clicks on it and then tried to move the car with the engine. It could just about move, 6 clicks locked it and with 4 I could move it with my foot out of the door. I can only think the heat has caused it to hold initially and then as components have cooled and contracted it’s released (like the Citroen’s a while back). I’ve told my wife to leave it in gear now and she’s emailed Ford with her concerns. Thank goodness no one was walking on the pavement and no cars were damaged. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561459 Mon Jul 16 2018 3:52pm
HughN
Wales
And I thought Lincolnshire was flat! Laughing
Post #561463 Mon Jul 16 2018 4:46pm
Disco_Mikey
Used to panic about the same with my Fabia VRS
Pull handbrake on fully. Foot on brake pedal, always gave an extra 2 clicks Thumbs Up
Post #561474 Mon Jul 16 2018 7:56pm
Brit Plumber
It’s booked in for a check up on Saturday. It’s only done 4000 miles so I doubt they will find anything wrong. 2019 5.0 SC SVA (Current)
Post #561574 Wed Jul 18 2018 8:50pm
sally
Maybe a few of the teeth on the ratchet part of the handbrake lever are worn. When you pull it up 5-7 clicks, give it a wiggle, Often it will jump down a tooth and thats enough for it to roll away.
Glad no one was hurt. 2012 Evoque
2014 Sport Autobiography
2015 SVR for the fun stuff
2016 Evoque SI4 Dynamic Lux for the daily drive
2016 Defender 90
2018 SVR
Post #561619 Thu Jul 19 2018 1:01pm
Tim in Scotland
Put a couple of big stones or bricks behind the wheels as a back up, I do that to all my cars when I go to sea, just in case. On one occasion it also delayed a would be thief long enough for plod to catch him red-handed trying to figure out why the car wouldn’t move backwards! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #561621 Thu Jul 19 2018 1:32pm
HughN
Wales
This is why older Saabs wouldn't let they keys be removed from the ignition unless the gearbox was in reverse. Wink
(parked next to a kerb, there's the old 'angle the wheels' thing).
Post #561622 Thu Jul 19 2018 1:37pm
