![]() | Home > Detailing & Car Cleaning > Snow foam |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
Chemical Guys No Touch snow foam is the best I have used and tried most of them |
I use Bilt Hamber Auto foam which is much better than valet pro ph neutral that I’ve been using for years,,it doesn’t foam as much but it does the job better plus I use it through a pump sprayer rather than a snow foam lance this way you don’t use as much foam.
Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71 ![]() ![]() ![]() |
Agree with this comment but struggle to buy this stuff anywhere. It like rocking horse s#*t. I have reverted to bilt hamber auto foam because of this. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
If you want a foam which hangs around..
You don’t really want it to hang around,,you want it to run off the car to take the muck with it.
That stuff does run off obviously, but not too quick. It has time to soak into the muck before running off |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
After giving it a second chance, after getting the mix ratio wrong |
Devon,,do you use it in a snow foam lance or a pump sprayer.? Most of the guys on deatailingworld.co.uk recommend a pump sprayer as you don’t use as much product.I use it in a 7 litre pump sprayer,once it’s mixed to the right ratio you can leave in the sprayer the product you don’t use so the 7 litres usually does the RRS 4-5 washes.
Hi Andy
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
+1 for magifoam, here's a few pictures of the Scooby taken before and after using magifoam, no hand washing, just a power wash after the snowfoam had done its thing.
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 ![]() ![]() |
Bilt Hamber gets the ![]() Current: MY2023 3.0 SDV6 Autobiography in Eiger Grey Gone: MY2019 3.0 SDV6 Autobiography in Carpathian Grey Gone: MY2015 4.4 SDV8 Autobiography in Corris Grey with ebony and lunar leather Gone: MY2013 3.0 SDV6 HSE Black Edition in Orkney Grey, piano trim, black leather with contrast stitch |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5032 ![]() ![]() ![]() |
I used the last of the Valet Pro PH neutral today. Haven't used it for ages.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
I have been using the Gtechniq W6 snow foam and it seems to be quit good but used the last of it yesterday so not sure if I should just buy another bottle or try something else.
I don’t rate Autoglymm snow foam - very thin and doesn’t stick on the car for long. I apply it with a Karcher snow foam tool and no matter what setting I use that the foam is more like whipped up washing up liquid than what the detailers put on my cars - which is GTechniq snow foam applied with pumped sprayer and it makes a very dense foam that was allowed (on a very hot sunny day) the stay on the for a while and it didn’t slide off quickly.
