Home > Faults & Fixes > Keys not locking
Plazmapete
Keys not locking
I'm having a problem with locking and unlocking the car. Both keys now will not work. I have tested the keys and they are emitting a signal. I have tried to re sync them to the car but still won't work. Any help would be appreciated. New alternator.
Gearbox flush.
Post #559209 Sun Jun 17 2018 2:52pm
geoffsnook
There's a guy in ebay that refurb's them for about £25 he did mine so send one key of and see if that sort's it out it's a quick turn around Thumbs Up
Post #559256 Mon Jun 18 2018 7:23am
Nigex4x4
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
How do you re sync the keyfobs please?
I've just got my new keyfob back from our friend on Ebay but it's still no go, I'm sure there was a process for re syncing them but I cant remember it Plazmapete mentioned doing it, how please?
thnx in advance 2005 RRS HSE Arctic Frost (more like Scotch mist)
"When you are going through Hell - keep going!" Sir W Churchill
Free plumbing advice to fellow sufferers
Post #586828 Thu Sep 12 2019 8:47pm
geoffsnook
I never had an issue with my keys perhaps there is another issue
Post #586829 Thu Sep 12 2019 8:56pm
geoffsnook
Perhaps a receiver issue search on the site I’m sure I have seen some with a failing receiver also Thumbs Up
Post #586830 Thu Sep 12 2019 8:58pm
Gallb60
Re: How do you re sync the keyfobs please?
thnx in advance
Did you get this issue sorted as i am having the same problem
Post #603897 Sat Aug 29 2020 12:46pm
Plazmapete
Yesterday none of my 3 keys would lock or unlock the car. Last night all 3 were working. But today none if them are working again. Any help?? New alternator.
Gearbox flush.
Post #610193 Thu Feb 18 2021 1:28pm
search for 3 wire splice
basically inside the car, along the passenger sill at the front is the wiring loom.
In there lots of green wires which join in a crimp joint.
It probably needs re doing. (soldering ideally)
Post #610197 Thu Feb 18 2021 3:08pm
Plazmapete
I have searched for the 3 wire splice but not found much. How do I get the sill trim covers up? New alternator.
Gearbox flush.
Post #610210 Fri Feb 19 2021 7:33am
Plazmapete
Can only find a splice with 2 green wires. New alternator.
Gearbox flush.
Post #610211 Fri Feb 19 2021 9:29am
Does appear like it.
Loads on disco forum
https://www.disco3.co.uk/forum/central-loc...een+splice
Post #610222 Fri Feb 19 2021 11:34am
Plazmapete
I haven't done it yet as there are only 2 wires not 3. Also the wires are bone dry. After putting some kitchen towel under the cables the towel was only damp. New alternator.
Gearbox flush.
Post #610224 Fri Feb 19 2021 11:48am
I think I saw an example on the disco forum of a pic with 2 wires
Have a read over there. Lots of posts.
Mind you , you haven’t got much to loose.
At least it’s eliminated if nothing else
Post #610226 Fri Feb 19 2021 12:01pm
