Home > Technical > rear timing belt
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
rear timing belt
could anyone tell me if the rear timing belt on a 2012 3.0 rrs as to be timed up, I know on the 2.7 it's not Sad
Thanks
Post #558772 Tue Jun 12 2018 1:10pm
Do a search on here and Disco3.co.uk but from memory, yes the 3.0 does have to be timed. 2012 SDV6 - it's missing a couple of cylinders
Post #558783 Tue Jun 12 2018 3:08pm
PC76
Yes it is timed and a pain the arse as a vacuum pipe now further restricts access due to it being routed directly infront of the cover. Censored
Post #558788 Tue Jun 12 2018 4:33pm
Disco_Mikey
It is timed, but no more difficult than a 2.7 belt
There is a locking tool to time the pump correctly
Post #558789 Tue Jun 12 2018 5:23pm
blueiceplus
Thanks, if I remove the old one and replace it with the now one with out turning the engine over, would that be ok, as that's what I did when I replace the one on my 2.7 engine and it was ok.
Post #558797 Tue Jun 12 2018 6:42pm
Disco_Mikey
As long as the marks line up Thumbs Up
Post #558800 Tue Jun 12 2018 7:01pm
Iggy
United Kingdom 2011 Range Rover Sport SDV6 HSE Santorini Black
Sorry to tag on someone else's post not managed to start my own. Hi all a have a question I'm doing the rear belt on a rrs 3.0 having done the front. The crank/camshafts/fuel pump are all locked. Can I just fit the replacement belt ? Why would I need to line up the white lines on the belt with the line on the camshaft sprocket. I don't see any mark on the fuel pump drive.
Post #565580 Thu Sep 20 2018 10:57pm
blueiceplus
3.0 pump timing
what white lines are you talking about on the belt ? if its all locked in position just fit the new belt, if your useing the old belt it dosen't matter about any marks you put on it Thumbs Up
Post #565583 Fri Sep 21 2018 5:49am
Disco_Mikey
In theory, it will be fine as long as everything is timed up.
The marks on the belt are there for correct alignment, to ensure the cam + pump are aligned
In practice, it takes no extra effort to align the marks, so may as well Thumbs Up
Post #565640 Fri Sep 21 2018 6:22pm
Iggy
Hi all I have the rear belt on ignoring the white lines on it. I am struggling to get my arm down the back to fit the tensioner before l Rolling with laughter lock the fuel pump getting the pin in that will be a mission in itself. I have disconnected the vacuum pipe at both ends at the back to make more room. I think I'm afraid of dropping it an it getting lodged down the back. Any ideas would be greatly appreciated. I have checked the wife's arms an there bigger than mine which is worrying. Rolling with laughter
Post #565643 Fri Sep 21 2018 6:32pm
Iggy
Regarding the timing belt white lines I could line up with the camshaft sprocket. However I cannot for the life of me see any line or indent on the fuel pump drive. Am I missing something?
Post #565645 Fri Sep 21 2018 6:40pm
Have you removed the grill?
Also try sitting on the air box. They can take a lot of weight Laughing
Try not to cross thread it
And make sure the tag goes into the cut out
I put a string around the belt to keep tension
Post #565646 Fri Sep 21 2018 6:43pm
Iggy
The job goes on an on. The rear belt is on as is the tensioner before pulling the pin. I fitted the fuel pump locking tool to the drive sprocket which was easy. But the pin will not locate in the hole in the engine I can turn the sprocket maybe 5mm each way before the tool touches the casing and I have tapered the end of the pin and it fits fine without the tool attached.
Any ideas would be appreciated.
Post #565770 Sun Sep 23 2018 7:41pm
