Home > General (L494) > Does ghost immobiliser void LR warranty? |
I think the servicing bit about Ghost has been covered before - you might find a thread if you use the search function with “Ghost” as the search topic. I cannot see how it would affect the lease agreement although they may want to charge you to have it removed and any wiring holes repaired if you are handing the car back at the end of the lease. I’m sure that there will be a “service” mode like the OEM system has 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 25 2018 8:25am |
Busa1400 Member Since: 09 Mar 2018 Location: Leeds Posts: 20 |
You can switch it off when it goes in for servicing so they would not know it was on there. It also has a service mode so for when it goes in the garage, provided they do not go above 30 mph it won't reactivate |
Fri May 25 2018 12:48pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
Recently had to call LR Assist out for a battery issue on my car....he was not in the slight bothered that my car had either Ghost or an aftermarket dashcam fitted... think they are rather common nowadays... |
Fri May 25 2018 1:10pm |
Gingerg978 Member Since: 18 Jan 2018 Location: Berkshire Posts: 67 |
Not sure about the warranty.
Fri May 25 2018 2:25pm |
