Home > General (L494) > 20" wheels
Been-and-dunit
20" wheels
Could any one tell me what happens if I put 20" wheels on my L494 Dynamic ,i.e. Does it alter the speedo.Thank you
Post #555951 Mon May 07 2018 6:37pm
Tim in Scotland
Not if you put the right profile tyres on the wheels. Iirc you can put wheel between 19 and 22” on so long as you use the profile as given in the plate in the door jam. Car is designed for them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #555957 Mon May 07 2018 7:32pm
Been-and-dunit
Thank you for that Tim Thumbs Up
Post #555960 Mon May 07 2018 7:40pm
Tim in Scotland
Auto correction made ‘profile’ into ‘price’ - I have corrected it now 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #555963 Mon May 07 2018 8:19pm
Been-and-dunit
Yes Tim I did work out what you ment .thank you very much Smile
Post #555964 Mon May 07 2018 8:22pm
Tyrefitter
Re: 20" wheels
255/55r20 iirc is the equivalent to 275/45r21 or 275/40r22.ive got the site on computer at work for working out different sizes.Also depends on wheel make So to clear the 20” Brembo’s
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #555965 Mon May 07 2018 8:54pm
IRBails
Australia
I run 285/50 R20 which are slightly larger However no scrapes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #555971 Mon May 07 2018 11:37pm
Tyrefitter
IRBails,,have you got 4 space savers on yours,185/50r20 Shocked Shocked
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #555975 Tue May 08 2018 5:58am
IRBails
Australia
What are space savers? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #555978 Tue May 08 2018 6:50am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Extra thin wheels used as a temporary replacement on gettting a puncture, so called because they are about half the width of the usual tyre. 185 is very thin.
Post #555980 Tue May 08 2018 7:11am
IRBails
Australia
fixed worked it out? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #555988 Tue May 08 2018 8:55am
Godfry
Watch out for the offset. I tried to fit my 20” wheels from the L320, that have a 49 offset, to the L494 with 20” Brembos and the wheel weights rubbed on the brake calipers slightly. Concerned about insurance issues and warranty so put the original 21” with 53 offset back on. Wanted to use the 20” with 255/55 profile winter tyres which would not alter the speedometer readings
Post #556051 Wed May 09 2018 7:41am
Been-and-dunit
So could I put style 520 split five on my L494 Dynamic with brembos thanks guys Thumbs Up
Post #556062 Wed May 09 2018 9:41am
Godfry
Sorry I gave a bit of a bum steer this morning, as the offset is the other way around.
L320 20" V spoke wheels is 53 offset and the L494 21" 507 wheels have a 49 offset, you would have thought that 4mm would not make all that difference, but just a bit too tight against the Brembo 20" callipers . I could have fitted 5mm spacers but then this would have pushed it with the studs, hence the backing off, because of insurance and warranty.
From what I have found the 20" 520 wheels have a 47 offset (check on the inside of the wheels as per photo and you will see the offset), and are only 8.5" wide and are original equipment on the L494, but you will still need to check the clearance against the callipers, maybe landrover can help.
A good website for checking wheel dimensions is www.wheel-size.com but it is still down to you to check, but makes a good guide.
let me know how you go on as i have been looking at these wheels to fit the winther tyres on
Post #556071 Wed May 09 2018 1:54pm
Been-and-dunit
Thank you I will look into it Very Happy
Post #556082 Wed May 09 2018 3:53pm
