Home > Faults & Fixes > Washer Bottle leaking
Brit Plumber
My Sport has developed its first fault, it’s sprung a leak from the washer bottle and it can empty in a matter of a few days. Can someone tell me how to access it before I go removing unnecessary parts. I hope/guess it’s a case of remove the LH wheel and arch liner, see a split right in front of me, put a band aid on it and it’s fixed for ever. Reality will be that I can’t find a leak, have a fight to replace it and damage something else in the process. TIA. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #554690 Sat Apr 21 2018 7:16am
If you are lucky it might just be one of the rubber seals that the washer pumps or low level sensor fit into.
Post #554691 Sat Apr 21 2018 7:40am
gogsy1956
There are a couple of posts on here regarding the removal of the washer bottle,, one mentions removing the front bumper but one guy managed by taking out the front fog light, but it was quite tricky. Do a search for the topic 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #554705 Sat Apr 21 2018 3:46pm
Buckster
Easy to access with front bumper removal, not actually that difficult. No idea how hard it would be removing just the headlight 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #554709 Sat Apr 21 2018 5:43pm
geoffsnook
with just the fog light out it would be really tricky to get the bolts out that hold it in but you would need to undo the bolts that hold the bumper on at the bottom to get it out and that is the hardest part to taking off a front bumper to be honest as they will be rusted in or at least very hard to release Thumbs Up
Post #554728 Sun Apr 22 2018 5:46am
According to the workshop manual, to access the pumps only remove wheel arch liner, to remove bottle have to remove front bumper.
Sometimes in the long run it works out quicker doing it by the "book" rather than some of the so called quick methods.
Post #554729 Sun Apr 22 2018 6:24am
Brit Plumber
Thanks chaps, I’ve had a look at some of the previous threads and I’ve now seen what I need to do. I’ll remove the LH inner arch liner to see if it’s a seal on the pumps and or filler neck. If it is, great I’ll fix it, if not and it’s a split in the bottle I’ll put it back together and order a new bottle. Probably no point in trying to fix a split. 2019 5.0 SC SVA (Current)
Post #554731 Sun Apr 22 2018 7:14am
Brit Plumber
Just to wrap this up, I had chance today to detach the front of the arch liner and I found one of the pipes had split at the connection to a pump. Cheap fix, cut the end of the pipe off and reattached.
Post #555094 Thu Apr 26 2018 1:01pm
Scrumpy
Nice! It's always satisfying when it turns out to be cheap and easy like that. Feel like you got one over on the money eating beast!!! 2016 RRS SVR Estoril Blue
Post #555098 Thu Apr 26 2018 1:19pm
