Home > General > Copious clouds of blue smoke
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Just been to the garage due to the cloud of blue smoke I leave behind when I accelerate and they confirmed what I have suspected - weeping oil seal on one of the turbos! Many thousands of pounds for the repair but on a cheery note, at least they can replace a leaking gasket whilst the engine is out! Sigh!
Post #553467 Sun Apr 08 2018 8:49am
Was there not something about a turbo oil feed/drain tube issue causing this, which was at one point a warranty repair, could be completely wrong though, sure someone will be along that knows for sure.
Google LTB00487v6 it may help, or have a look at File No. 1 in my gallery.
Post #553468 Sun Apr 08 2018 8:56am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
I seem to remember what Col is talking about,
Have a look at these, it might be of some help.
https://www.disco3.co.uk/gallery/albums/us...0-%203.pdf
https://www.disco3.co.uk/forum/topic132471.html
Post #553469 Sun Apr 08 2018 9:02am
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Take it to another garage before You commit to any repairs , I have the same car as you and I just had my second turbo oil drain pipe replaced .
The symptoms of this are excessive blue smoke when you boot it and to frequent dpf regeneration .
It's a common issue the second turbo drains to low in the sump causing oil to pool in the turbo due to low air pressure .the second turbo does not provide pressure until above 3000rpm. The cure is a shorter pipe that drains into The block not sump.
Post #553474 Sun Apr 08 2018 9:44am
Disco_Mikey
1st step of repair procedure Thumbs Up
Post #553477 Sun Apr 08 2018 9:53am
Stevepd
Keep us in the loop on how you get on.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #553560 Sun Apr 08 2018 7:21pm
PC76
Any update on this?
Post #559128 Sat Jun 16 2018 2:14pm
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
I had the same issue.
If you search for this problem then you should find that within a VIN series, there was a Technical Bulletin and as mentioned it is a matter of changing one of the vent pipes for the right hand turbo.
Not a cheap fix but, it does what it says on the tin and hey presto no more heavy smoke when heavy acceleration.
Post #559219 Sun Jun 17 2018 4:59pm
RJM16
I think this is the one.
Technical Bulletin LTB00487v6 3.0 TDV6 Excessive Exhaust Smoke
Post #559220 Sun Jun 17 2018 5:03pm
Bladerunner
Just got my RRS back today after having the turbo return pipe replaced and i am glad to say i am now smoke free.
Post #561272 Thu Jul 12 2018 4:56pm
RJM16
It’s more a piece of mind moment when you can put your foot down and not push out that hazy cloud of smog behind you.
Post #561274 Thu Jul 12 2018 5:34pm
Salisburylander
Just picked the car up from the garage. Turbo pipe and compressor relief valve have now been replaced and the intercooler rinsed out; hopefully, this will stop the excessive smoke!
Post #561835 Mon Jul 23 2018 1:53pm
bogrole
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I have just had mine done too, and now all is well! No more people flashing headlights at me.
Post #569924 Tue Nov 27 2018 6:18pm
Salisburylander
The car has been smoke free since the work was done. It also had a bit more go to it as well; this was probably due to the intercooler being washed out.
Post #569930 Tue Nov 27 2018 6:54pm
Salisburylander
The garage said that if the turbos needed replacing, they usually change the pipework/relief valve as well to the newer specification. So if it had continued to smoke excessively after the change, then the chances are that it would indeed be the turbos.
Post #569931 Tue Nov 27 2018 7:01pm
