Home > General > Copious clouds of blue smoke |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Was there not something about a turbo oil feed/drain tube issue causing this, which was at one point a warranty repair, could be completely wrong though, sure someone will be along that knows for sure.
Sun Apr 08 2018 7:56am |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
I seem to remember what Col is talking about,
Sun Apr 08 2018 8:02am |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
Take it to another garage before You commit to any repairs , I have the same car as you and I just had my second turbo oil drain pipe replaced .
Sun Apr 08 2018 8:44am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
1st step of repair procedure |
Sun Apr 08 2018 8:53am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Keep us in the loop on how you get on.
Sun Apr 08 2018 6:21pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Any update on this? |
Sat Jun 16 2018 1:14pm |
RJM16 Member Since: 11 Nov 2016 Location: Worcestershire Posts: 29 |
I had the same issue.
Sun Jun 17 2018 3:59pm |
I think this is the one.
Sun Jun 17 2018 4:03pm |
Bladerunner Member Since: 30 Apr 2018 Location: Kirkcaldy Posts: 17 |
Just got my RRS back today after having the turbo return pipe replaced and i am glad to say i am now smoke free. |
Thu Jul 12 2018 3:56pm |
It’s more a piece of mind moment when you can put your foot down and not push out that hazy cloud of smog behind you. |
Thu Jul 12 2018 4:34pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 245 |
Just picked the car up from the garage. Turbo pipe and compressor relief valve have now been replaced and the intercooler rinsed out; hopefully, this will stop the excessive smoke! |
Mon Jul 23 2018 12:53pm |
bogrole Member Since: 17 Nov 2018 Location: BIRMINGHAM Posts: 2 |
I have just had mine done too, and now all is well! No more people flashing headlights at me. |
Tue Nov 27 2018 5:18pm |
The car has been smoke free since the work was done. It also had a bit more go to it as well; this was probably due to the intercooler being washed out. |
Tue Nov 27 2018 5:54pm |
The garage said that if the turbos needed replacing, they usually change the pipework/relief valve as well to the newer specification. So if it had continued to smoke excessively after the change, then the chances are that it would indeed be the turbos. |
Tue Nov 27 2018 6:01pm |
