![]() | Home > Wheels & Tyres > Lost Locking Wheelnut Key. Which One Do I need?! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
There are Twenty starting at the letter "A" through to "W" however there will be some letters missing i.e. I, O, Q, if you go to a dealer they should have a kit to remove them and probably be able to tell which key you need
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
The Main dealer is the place to go, although you may have to buy a new set of locknuts. My new S class Merc was delivered with no locknut key. They just removed the locknuts as they have a universal tool & replaced them with a new set. They certainly will not have any locknut keys in stock which fit your car |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
There will be a small letter stamped on one of your locking nuts, that's all that is needed to order a new one £12.00 Sophie Alltoft
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Dan, Isn't the letter stamped on the end of the missing key, not the locking nut itself ?. otherwise anybody could obtain right key by looking at the nuts. Cheers Col |
mikefarnham Member Since: 25 Mar 2018 Location: Leatherhead Posts: 3 ![]() ![]() |
Firstly, well done and thank you everyone. I had posted my question in several places and I received the fastest, most informed and friendly responses here.
Ptchw Member Since: 27 Aug 2017 Location: Richmond Posts: 5 ![]() ![]() |
I had this exact issue a couple of weeks ago, I went to Land Rover Wimbledon, they have a “master set” and simply tried each one till they found the one that fit, sold me that one then and there, and ordered one in to replace the one in their set.
Yes, dealers vary substantially.
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 393 ![]() ![]() ![]() |
You mean, the supplying dealer messed up? Crikey, that does sound unusual (dripping with sarcasm emoji) Merc C220 estate Sport AMG
