Home > Technical > Bushes query.
Cymruambyth
Wales
^^^^ Was it QR Sport? Had my ST done there...good guys. I wouldn`t even attempt it myself. Don`t do spanners on cars anymore Very Happy Steve.
Post #554595 Thu Apr 19 2018 3:33pm
PC76
Yes i think it was.
if you want to contribute to the hire of the garage unit i use and can wait till the 18th May i could do them for you......
i have given up looking for a decent local indy so will be changing my timing belt then once back from my jolly..
Post #554604 Thu Apr 19 2018 6:06pm
DEVON
“if you want to contribute to the hire of the garage unit i use and can wait till the 18th May i could do them for you...... “
That’s a very nice offer PC76
I would contribute just to watch how it was done Bow down
Post #554710 Sat Apr 21 2018 5:53pm
Red Arrow
Better fitting Poly bushes on the new or old wishbones makes a lot of difference Thumbs Up
Post #554712 Sat Apr 21 2018 6:00pm
DEVON
I’m under the impression that replacing the whole arm is easier , because sometimes you have to cut the old arm off ?
+ I’m not sure how easy/hard it is to press in/out the bushes Thumbs Up
Post #554718 Sat Apr 21 2018 7:32pm
PC76
it was relatively easy to replace the arms. having a good impact gun is highly recommended!!
Post #554831 Mon Apr 23 2018 11:38am
Socast
Lower arms aren't usually that bad, it's the uppers that are pretty much always seized and require cutting out, most people replace the whole arm as its easier (and quicker) than replacing the bushes in the old arm and not all that expensive to buy the complete arm.
Advanced factors do a kit that comes with pre-fitted poly bushes, I've got them front and rear (lower arms) on my sport and they do make the ride a little harsher. The front bushes make more difference to the ride than the rear I found.
I've kept my old arms as I will renew the bushes in them and then I can hot-swap if and when the poly bushes fail Rolling Eyes
Post #554868 Mon Apr 23 2018 5:12pm
DEVON
Thanks Socast and PC76
That’s good to know . Thumbs Up
when I bought my Sport I didn't own a single spanner , Now an impact gun is going to be added
To my vastly growing collection of garage tools Rolling with laughter
Post #554873 Mon Apr 23 2018 6:17pm
