Home > Technical > TDV8 Dr Tranny? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
Had mine added when i got the flush done, otherwise you would have to add it via the level plug,, assuming there is any free space. Bite the bullet and have a flush. 2010 RRS, TDV8
Thu Mar 15 2018 7:49pm |
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 |
Hi Gogsy,
Thu Mar 15 2018 8:16pm |
You can add it via the oil pipe that feeds to the radiator, there is a post on here that has pictures showing exactly which pipe to remove So you can add it. |
Fri Mar 16 2018 9:00am |
Hi Socast,
Fri Mar 16 2018 9:14am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Not on the TDV8. This has a separate cooler for the transmission. I doubt getting in to the cooler, removing one of the pipes and getting the Dr Tranny in without loosing fluid would be easy. Putting the Dr Tranny in via the gearbox fill plug would be easier. The vehicle does need to be lifted on one side to prevent the oil coming out of the fill plug though. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Mar 16 2018 9:52am |
They all use the same gearbox (although the SC and the TDV8 have slight internal differences to the TDV6, the externals are the same). The cooling arrangements differ between models, however. The TDV8 has a separate oil/water cooler where the SC and TDV6 use a cooler that is part of the radiator. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Mar 16 2018 9:54am |
I could be wrong, but I'm pretty sure that they all have the same gearbox (facelift models have a different box) it's the ratios on the diff's that are different. |
Fri Mar 16 2018 10:02am |
Fri Mar 16 2018 10:58am |
I just spoke to another local LR Specialist they said, "we don't do flushes we will only change the oil and filter as the first stage
Fri Mar 16 2018 1:50pm |
I paid £275 with Dr tranny added at Quattro autocare in Yorkshire, which seems to be an average price 2010 RRS, TDV8
Fri Mar 16 2018 2:19pm |
Hi Gogsy,
Fri Mar 16 2018 2:29pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
you probably better off starting at a specialist (rather for them to have to check someone else's work and charge you for it)
Fri Mar 16 2018 2:33pm |
Hi Andy,
Fri Mar 16 2018 2:57pm |
The SC (and I think the TDV8 too) has an extra planet gear and extra clutch plates in the gearbox to handle the extra grunt produced by the engine. Other than that they're all the same. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Mar 16 2018 3:31pm |
