![]() | Home > Technical > TDV8 Dr Tranny? |
Had mine added when i got the flush done, otherwise you would have to add it via the level plug,, assuming there is any free space. Bite the bullet and have a flush. 2010 RRS, TDV8
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 ![]() ![]() ![]() |
Hi Gogsy,
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
You can add it via the oil pipe that feeds to the radiator, there is a post on here that has pictures showing exactly which pipe to remove So you can add it. |
Hi Socast,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Not on the TDV8. This has a separate cooler for the transmission. I doubt getting in to the cooler, removing one of the pipes and getting the Dr Tranny in without loosing fluid would be easy. Putting the Dr Tranny in via the gearbox fill plug would be easier. The vehicle does need to be lifted on one side to prevent the oil coming out of the fill plug though. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
They all use the same gearbox (although the SC and the TDV8 have slight internal differences to the TDV6, the externals are the same). The cooling arrangements differ between models, however. The TDV8 has a separate oil/water cooler where the SC and TDV6 use a cooler that is part of the radiator. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I could be wrong, but I'm pretty sure that they all have the same gearbox (facelift models have a different box) it's the ratios on the diff's that are different. |
I just spoke to another local LR Specialist they said, "we don't do flushes we will only change the oil and filter as the first stage
I paid £275 with Dr tranny added at Quattro autocare in Yorkshire, which seems to be an average price 2010 RRS, TDV8
Hi Gogsy,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
you probably better off starting at a specialist (rather for them to have to check someone else's work and charge you for it)
Hi Andy,
The SC (and I think the TDV8 too) has an extra planet gear and extra clutch plates in the gearbox to handle the extra grunt produced by the engine. Other than that they're all the same. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
