Home > Wheels & Tyres > Mixing 40 profile and 45 profile? |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Can I run 275 45 R20's on the rear and 275 40 R20 on the front? I guess not as it will screw up something.
Tue Mar 13 2018 8:22am |
Cheers Buckster. I thought as much but worth asking Robin
Tue Mar 13 2018 9:15am |
You`d be increasing the diameter of only 2 wheels then.
Tue Mar 13 2018 11:13am |
jzive Member Since: 23 Feb 2014 Location: Essex Posts: 80 |
Agreed, would advise against mixing profiles. |
Tue Mar 13 2018 12:23pm |
Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Tue Mar 13 2018 12:36pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
2016 RRS SVR Estoril Blue
Tue Mar 13 2018 1:50pm |
http://www.rrsport.co.uk/forum/topic35871.html
Tue Mar 13 2018 1:53pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Put a decent pair of part worn tyres on to match the others Robin
Tue Mar 13 2018 8:40pm |
Now there’s a thought. Robin
Tue Mar 13 2018 11:06pm |
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 |
Yes, you can. A lot of BMW's have wider wheels on the back, and therefore have a different profile. Eg, you would have say a 305/45 on the rear. You would need to work out exactly which on a calculator. The 40 just means 40% of the width. 2012 RRS SDV6
Wed Mar 14 2018 7:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5018 |
Wed Mar 14 2018 8:58am |
Agreed, no-one suggested putting a 245 on a 9.5j rim from what I can see. I just said it can be done. 2012 RRS SDV6
Wed Mar 14 2018 9:08am |
The 40/45 is the profile (height), not the width though. The staggered setup on the likes of M3`s won`t affect the overall circumference just because the rears are wider. Steve. |
Wed Mar 14 2018 9:50am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The BMW are designed with this odd tyre arrangement from the outset, however. The RRS is designed to run the same all round. Just because you can, doesn't mean you should. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Mar 14 2018 10:23am |
