Home > Wheels & Tyres > Mixing 40 profile and 45 profile?
Eaters
Can I run 275 45 R20's on the rear and 275 40 R20 on the front? I guess not as it will screw up something.
Currently have 275 40 R20 all round but would like to change to 45 profile for a bit more comfort. However front only went on 8000 miles ago so still have quite a bit of life in them. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #551180 Tue Mar 13 2018 9:22am
Buckster
Not recommended mate 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #551183 Tue Mar 13 2018 10:04am
Eaters
Cheers Buckster. I thought as much but worth asking Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #551186 Tue Mar 13 2018 10:15am
Cymruambyth
Wales
You`d be increasing the diameter of only 2 wheels then.
It`ll look something like this Laughing
 Steve.
Post #551195 Tue Mar 13 2018 12:13pm
jzive
Agreed, would advise against mixing profiles.
Post #551204 Tue Mar 13 2018 1:23pm
Eaters
Rolling with laughter Robin
Gone:
MGZTT 190 2.5
Post #551206 Tue Mar 13 2018 1:36pm
Scrumpy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter 2016 RRS SVR Estoril Blue
Post #551209 Tue Mar 13 2018 2:50pm
Socast
http://www.rrsport.co.uk/forum/topic35871.html
Mixed wheel sizes cause headaches Thumbs Up
Post #551210 Tue Mar 13 2018 2:53pm
riverblanche
Put a decent pair of part worn tyres on to match the others Robin
Then change all four next time for the other size your after Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #551263 Tue Mar 13 2018 9:40pm
Eaters
Now there’s a thought. Thumbs Up Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #551288 Wed Mar 14 2018 12:06am
RallyXS
Yes, you can. A lot of BMW's have wider wheels on the back, and therefore have a different profile. Eg, you would have say a 305/45 on the rear. You would need to work out exactly which on a calculator. The 40 just means 40% of the width. 2012 RRS SDV6
2014 BMW 320d X-Drive Touring
1999 VW Polo stage rally car
Post #551299 Wed Mar 14 2018 8:46am
If my calculations are correct, if you run a 275/40 x 20 tyre on the front you would need to run a 245/45 x 20 on the rear to get almost the same rolling radius. 275/40 x 20 is 228.71cm a 245/45 x 20 is 228.87cm not sure I would want to put a 245 tyre on a 9.5J rim. and run it on a 2.5 ton Sport. Also kind of defeats what Robin is trying to achieve surely.
Post #551305 Wed Mar 14 2018 9:58am
RallyXS
Agreed, no-one suggested putting a 245 on a 9.5j rim from what I can see. I just said it can be done. 2012 RRS SDV6
Post #551307 Wed Mar 14 2018 10:08am
Cymruambyth
Wales
The 40/45 is the profile (height), not the width though. The staggered setup on the likes of M3`s won`t affect the overall circumference just because the rears are wider. Steve.
Post #551318 Wed Mar 14 2018 10:50am
The BMW are designed with this odd tyre arrangement from the outset, however. The RRS is designed to run the same all round.
Just because you can, doesn't mean you should. 2012 SDV6 - it's missing a couple of cylinders
Post #551327 Wed Mar 14 2018 11:23am
